Need a permit to install backflow preventer?
Discussion in 'Plumbing Building Code' started by danbarr, Jan 24, 2016.
  1. Jan 24, 2016 #1
    danbarr
    danbarr
    danbarr
    Jan 24, 2016
    I live in Seminole County Florida. My question is do I need to pull a permit if I install a backflow preventer on my main water line to the house?
    Thanks in advance!
    Dan
  2. Jan 24, 2016 #2
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional
    Jul 21, 2011
    3,223
    740
    Melbourne, Florida
    Yes you need a permit. Plus it has to be certified by a licensed back flow tester.
  3. Jan 24, 2016 #3
    phishfood
    phishfood
    phishfood
    Moderator Staff Member Professional Supporting Member
    Jan 18, 2010
    5,775
    992
    Orlando, FL
    Yes. And it needs to be tested and certified by a licensed backflow tester, and the certification sent to the water service provider.
    If you can't find someone to do the testing, I might be able to connect you with someone.
    Edit: John beats me to the punch once again!
  4. Jan 24, 2016 #4
    danbarr
    danbarr
    danbarr
    Jan 24, 2016
    Thanks for the help?
    Just one more nagging question:
    Can I install the backflow preventer myself?
  5. Jan 24, 2016 #5
    gargalaxy
    gargalaxy
    gargalaxy
    Professional Professional
    Oct 27, 2015
    40
    18
    , Central Fl
    You shouldn't install it. Once again, it has to be certified by a backflow tech.
    What kind of backflow do you want to install? Do you replacing an old or failed backflow?
  6. Jan 25, 2016 #6
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    If you have the skill to install it, I see no reason why you can't.
    The inspection is separate from installation.
    Why do you want to install a backflow?
    Is it being required by your water service provider?
    Permit required?
    The money grubbing bureaucracy wants permit fees for any modification to your plumbing. They just want to make sure you aren't installing it in violation of their rules.
    Kmason likes this.
  7. Jan 25, 2016 #7
    danbarr
    danbarr
    danbarr
    Jan 24, 2016
    I'm going to install the backflow preventer today. While replacing water meters with the wireless system Seminole county said they noticed there was a well pump (irrigation) on the property and sent a letter requiring a BFPA on the potable water line even though the irrigation system was totally separate from the potable water lines. Will be giving them a call on this before anything starts!
  8. Jan 28, 2016 #8
    Mr_David
    Mr_David
    Mr_David
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    Yeah, That makes since.
    Your water provider has no control of the water supply
    After their water passes through the meter, so they want to insure that IF there is ay cross connections that their system is protected from any cross contamination.
    johnjh2o likes this.
  9. Jul 20, 2016 #9
    watson
    watson
    watson
    Banned
    Jun 2, 2016
    10
    Yes, needs a permit and guaranteed by a licensed backflow tester.
  10. Jul 20, 2016 #10
    Mr_David
    Mr_David
    Mr_David
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    Was wondering why you posted on a 6 month old topic that seems to have been resolved.
    I looked and most of the other comments by you.
    This Parrot has wings. A bit slow but gets around.
    johnjh2o and Caduceus like this.
  11. Jul 20, 2016 #11
    Caduceus
    Caduceus
    Caduceus
    Apr 3, 2011
    1,288
    353
    Pittsburgh, PA
    A backflow device is required by the water compan.....oh, nevermind. Just noticed this was already addressed. My bad.:eek:
  12. Jan 18, 2017 #12
    skelly716
    skelly716
    skelly716
    Jan 18, 2017
    24
    San Diego, California
    I'm in Ca so I'd listen to John. Anytime you need to know if you need a permit or not always call the building department and ask. Each state gives each city, town, village or borough the freedom to adopt their own codes (municipal codes) as long as they're not more lenient than the state which is "minimum standards".
    As an inspector I get yelled at all the time by contractors "well LA lets me do it". My response is always "well you're standing San Diego".
    2 second call answers all your questions.
    Mr_David likes this.
  13. Jul 4, 2018 #13
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,433
    210
    Boston, Massachusetts
    hello...I live in mass....we are not require to have bfp at the main...you would need one for your irrigation IF it was connected to your main you would need one on a residential fire protection system IF it was connected to you main.....your system was engineered...that may be the reason...I was involved with a reno in an OFFICE BLD
    there was no need for a bfp on the water main there was one on the fire protection but he would not sign off on the plans unless this was done our project managers should have fought this now we have to test them for the life of the bld 2 time a year at 100 bucks + and it was dual containment!!!!!!!!!(2 bfps!!!!!!!!
  14. Jul 7, 2018 #14
    chiraldude
    chiraldude
    chiraldude
    Hardcore DYI-er
    Nov 16, 2013
    126
    27
    Southern Minnesota
    Nothing to add but I have to say that it's good to know that if I am ever in a situation with city water plus an irrigation pump, I should go to some extra effort to hide the pump so it is not easily found.
    Of course I would never connect two systems.
  15. Jul 7, 2018 #15
    johnjh2o
    johnjh2o
    johnjh2o
    Jul 21, 2011
    3,223
    740
    Melbourne, Florida
    You may not make a cross connection but can you say future owners of the property won't?
  16. Jul 8, 2018 #16
    chiraldude
    chiraldude
    chiraldude
    Hardcore DYI-er
    Nov 16, 2013
    126
    27
    Southern Minnesota
    Using that logic, every house should have a backflow preventer. A future owner may decide to drill a well, build a cistern, or any number of things that could cause backwards flow.
    The reality is that most people have limited budgets so adding expensive plumbing just because it's a good idea is not going to be on my to-do list if I can help it.
  17. Jul 19, 2018 #17
    watson
    watson
    watson
    Banned
    Jun 2, 2016
    10
    What are the common Gasketing Mistakes in Plumbing?
  18. Jul 19, 2018 #18
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,475
    262
    North Reading, Mass.
    An irrigation system off the city water is not the same as a well pump feeding an irrigation system. A well pump or separate source of water on site requires a High Hazard type backflow preventer.
    There are applications requiring either total containment or in premise containment, depending on type of hazard(s). In the case of well pumps total containment is a requirement for most if not all locations.
  19. Jul 19, 2018 #19
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,475
    262
    There's a difference between having a well and having the ability to drill one in the future. The line must be drawn somewhere and the general public would not want to have to pay to have a testable backflow preventer installed and test annually(+/-) based on potential.
  20. Jul 19, 2018 #20
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,475
    262
    All irrigation systems require some type of backflow protection device. typically they are the non-testable type and not a big deal. It's not until you have a separate piped water source on site that would kick in the requirement for total containment with a testable backflow preventer. If for some reason you used an irrigation pump on the puplic water supply that would not kick in the total containment requirement. A slightly different backflow device would typically be required due to the potential of back pressure on the public water supply.
Share This Page
