Move radiator to accommodate fridge?
DRAK92
Mar 8, 2019
Yorkshire
Hi how easy is it to move the radiator to accommodate a standard fridge of 65x60x186 ?
I have attached piks.
not hard at all if you have the knowledge to
to extend what ever the pipe is that is hooking that rascal up
you could move it so that the pipe on the right. is hooked into the opening on the right side of the moved radiator
and the only pipe you would have to move would be the pipe on the right moved to the left of the moved radiator
boiler needs to be shut down, system drained, move radiator, purge system, bleeed air
