jazzisjazz
Howdy all, Have a small problem with a leaking drain and hoping for a simple fix. I think the rubber ring is missing, I don't know if it would just be round or flat on the inside and angled on the outside of the same piece. Any help is appreciated. If I have the inside dia and the thickness, where should the outside be measured if needed to pick the most likely part to work and where should i look for it?
