main water pressure question
pmn
Nov 20, 2018
9
Columbus, OH
I have an problem with ver low flow at a bathroom most distant from my hot water heater. The hot water is barely flowing in the shower and the sink. In fact, I feel like most of my facility is suffering from low flow except possibly the urinal. I put a gauge on the shower head, it reads 38 psi. I also put a gauge in the 3/4" supply line to the (new) hot water heater - it too reads 38-40 psi. I then put a gauge on line right after the water meter which is as close as I can get to the street. With no water flowing, it reads a static 58psi. If I flush the toilet which is closest to the water meter, it drops to 48-50psi and stays there until the toilet stops running. Is 40 psi at the shower head normal? Is the 10 psi drop on the main from one toilet flush indicative of a FLOW problem rather than a PRESSURE problem? I'm going to call the city and ask them to take a look at their valve but wonder what others think about this. The state code information I can find says that 40 psi should be OK but it sure seems low to me.
Thanks!
havasu
Administrator
Staff member
Admin
Jan 5, 2010
9,531
1,380
Southern California,
It seems low to me as well. Can you go to a spigot outside, preferably as far from the PRV as possible and measure this?
pmn
Nov 20, 2018
9
Columbus, OH
Thanks for the reply! The only outside spigot is on the same wall as the meter - about 2 feet away :-(
havasu
Administrator
Staff member
Admin
Jan 5, 2010
9,531
1,380
Is this a house or mobile home? What type of plumbing do you have (Galvanized, CPVC, copper?) Many cities offer free replacement of the PRV's, so that would be your first call.
pmn
Nov 20, 2018
9
Columbus, OH
It's a small commercial office, has copper pipe. 3/4" copper supply to the water meter, 1" copper going to center of building where it then branches off to various places including the water heater which is a 3/4" copper line.
havasu
Administrator
Staff member
Admin
Jan 5, 2010
9,531
1,380
With what you have just typed, I'd call the water department who may either adjust or replace the PRV.
Diehard
Aug 19, 2017
2,640
469
North Reading, Mass.
I retracted my comments once I saw the additional comments.
You have a pressure reducing valve(PRV)?
Static pressure readings at the shower or water heater don't help. It's the flowing pressures(residual pressure) that should be evaluated. The only thing that static pressure readings at different locations within the bldg tell you, are the difference in elevation.
With a 10 psi pressure drop while flushing a toilet, I assumed no PRV.
pmn
Nov 20, 2018
9
Columbus, OH
You have a pressure reducing valve(PRV)? With a 10 psi pressure drop while flushing a toilet, I assumed no PRV.
There is no pressure reducing valve that I know of unless it is out at the street. Definitely not one inside the building.
There is a backflow valve, it just recently passed inspection by Koorsen. I have called the water company to schedule a visit by one of their techs.
Diehard
Aug 19, 2017
2,640
469
You may not get this far but for your info, I would record the pressure loss at the meter when flowing the maximum gpm possible from a nearest spigot or faucet from the meter. Once we know that, we can calculate what should be available at different fixtures.
ExtraMilePlumbing
Aug 21, 2014
512
87
I believe 40psi is the minimum citys are required to provide.i would start taking off aerators
Diehard
Aug 19, 2017
2,640
469
"The City of Dallas provides water to all services with a minimum pressure at the water meter of 25 pounds per square inch (psi). The State of Oregon has set a minimum pressure standard of 20 psi for public water systems. Most homes receive water at a pressure between 35 and 85 psi."
No aerators on showers.;)
FishScreener
Aug 23, 2018
328
92
83467
Those sound more like fire flow pressures, and not normal delivery pressure at the service. Which is normally 35 to 85-psi.
Diehard
Aug 19, 2017
2,640
469
Totally agree with you!
Of course, I just found that info on a web search. It was probably quoted out of context.
I know 20 psi is typical minimum for fire flow under all conditions.
I have been at isolated cases here in Mass. where due to various and/or unusual conditions town pressure was so low at the house we had to install a pressure booster system. Definitely not common.
pmn
Nov 20, 2018
9
Columbus, OH
I pulled aerators and also removed the showerhead completely. Same.... Hoping I don't have to put a pressure booster system on it. :(
Diehard
Aug 19, 2017
2,640
469
A static pressure of 58 psi isn't that bad if the fall off pressure isn't too bad.
In order to get an idea if the city supply has a problem once it gets flowing or whether your piping is restricting the flow vs pressure, you should check the pressure at the meter again with a flow rate that is measured(called the residual pressure). That is, a GPM reading. Get a 5 gallon pail or equivalent and time how long it takes to flow a specific amount of water. Record the pressure while flowing as wide open as convenient. Same idea as what you did with flushing of the toilet except you should get a flow rate, in GPM(gallons per minute).
Once we have that info, we can extrapolate what types of flow and pressure you should expect at various locations by looking at the the elevation differences and what the friction losses SHOULD be. Hopefully we can closely estimate if the problem is in your piping and/or with the city's supply.
EDIT: BTW...You had mention calling the water company to schedule a visit by one of their techs. Did that happen yet?
ExtraMilePlumbing
Aug 21, 2014
512
87
booster pumps require lots of maintenance especially if running 24/7
I would recommend upsizing water main 2 sizes minimum to see if that helps
Diehard
Aug 19, 2017
2,640
469
I believe finding where the problem is should come before arbitrarily replacing pieces of the system. But that's just me.
