Main shut off valve
flash man
Feb 12, 2020
6
Toronto
Hi
Might be an obvious question but when I turn my main water supply off (clockwise turn) I hear the sound of pressure and I see the water meter spinning slowly (when it wasn't moving before). Why does this occur? Toilets stop replenishing water so it seems as though the water is shut down.
Jeff Handy
Jul 5, 2019
1,671
289
Chicago suburbs
Post a video, this does not make sense.
Describe it better, is the shutoff right next to the meter?
Rossando
Jul 1, 2018
112
16
San Francisco
At the meter or are you turning the valve where it enters your property? Do you have pictures of this?
FishScreener
Aug 23, 2018
328
92
83467
Do you have a buried stop/drain valve with the weep hole, which has been installed backwards?
Diehard
Aug 19, 2017
2,640
469
North Reading, Mass.
Hi
When you say pressure, I assume you mean you hear flow.
Then you see the meter start to move. For how long does it show flow?
flash man
Feb 12, 2020
6
Toronto
Hi
1. Yes it's the shut off right under the meter.
2. I left it shut off for about 5 to 10 minutes but it does not stop showing flow.
3. All water stops to house except to laundry faucet, which seems unaffected and is located in basement next to meter.
For reference, here's a video after I turned off the water supply valve:
https://imgur.com/YJY93ue
Thanks,
Diehard
Aug 19, 2017
2,640
469
I'm assuming the flow you witnessed at the laundry faucet was very low and lacking pressure.
If that's the case, it sounds like a partial closure of the shut off valve and that the flowing pressure is restricted to the lowest fixture in the house.
Jeff Handy
Jul 5, 2019
1,671
289
Chicago suburbs
Diehard seems to have it diagnosed.
Your blurry video was pretty worthless.
Looks like the shutoff valve is failing, it does not close completely, which is very common.
Meanwhile, your explanation of the whole issue needs to be done again.
