Gozoman
Really need some help with this. I have a Triton LP thermostatic shower mixer valve. It is a simple gravity feed system with the cold and hot feeds coming from the loft directly above the bathroom. The cold water tank is situated in the loft and the hot water cylinder is situated in the airing cupboard in the bathroom with the hot feed going up into the loft across and down to the shower.
The problem is pressure. It has never been a power shower obviously but there was a decent enough pressure to have a shower, then it started to play up. When I turn it on with the thermostatic lever set to where it would normally be the pressure seems okay but then after about half a minute you can see the pressure dropping off. If I turn the thermostatic control to full cold the pressure goes back to normal, if I turn it to full hot it drops back to practically zero.
What I have done so far is the following. I have isolated the supplies and taken the valve off the wall. I have turned on the cold water and let it run for 10 minutes to clear the line. Did the same with the hot supply. I have run a hose up from the mains tap in the yard and connected up to each pipe in turn and used the mains pressure to blast the lines back to the cold tank. I have stripped the thermostatic valve completly and cleaned out the filters on both hot and cold inlets as well as flushing out the rest of the valve. It is a low pressure valve so there is no reducer fitted.
And that's it. I don't know what else to do. I thought it may be an air lock on the hot side but given that the hot water cylinder is fed from the bottom with the outlet at the top I can't see how that could be. Any ideas would be greatly appreciated as it's driving me nuts!
