Loud hammer noise with faucet, not sprayer?
Sophia777
Jul 26, 2020
NE Pennsylvania
Good day! I just replaced a kitchen faucet and a brand new issue has appeared. There is a water hammer noise and vibration when I use the faucet but the noise/vibration stops when I use the sprayer. The on/off water valves underneath are fully open. When the faucet tap is open, the sprayer dribbles. Is this a defective sprayer diverter on a brand new faucet? What could be causing this and/or how can I fix this? Many thanks for your time & input!!
Sophia777
Jul 26, 2020
NE Pennsylvania
Just adding a bit more clarity. I had a plumber come to replace the faucet. After finishing, the sound appeared. He felt it was likely an old valve not allowing full flow. He showed me how the hose was pulsing water (in a bucket) when not connected to the faucet. Are the issues all tied together, and/or do I have an old bad valve under the sink AND bad diverter on a new faucet? Or can the valve cause the noise and a drippy sprayer (only when tap is open)?
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,000
298
Boston, Massachusetts
If it’s pulsing with no connection to the faucet, sounds like a loose washer in the shut off valve most can be rebuilt
Jeff Handy
Jul 5, 2019
2,029
381
Chicago suburbs
Sounds like you have both issues, bad valve and diverter.
You might be able to learn which valve by closing one at a time.
