Last year I had a 500-gallon propane tank and a Rinani inside furnace installed in a small cabin in the Oregon Cascades, which is vacant most of the time. Works great. The heating cost were cut in half from electricity.
Next project is to replace the electric hot water tank which is located in the corner of an attached single garage, which is located next to an entry stairs into the house (the lowest, coldest point of the house).
So my $64 question is, would it be better to install the tankless unit in the garage (where the electric tank is) or essentially put it very close inside the house. Installation would be a little more complicated, with a little more plumbing work and venting work, but the unit would be at about 45 degrees F in the winter, as opposed to the garage which does get colder, typically 35 degrees. I'm a concerned the tankless unit could be subjected to cold, possibly freezing temperatures.
I've read that tankless units can have a 'heating element' so they don't get too cold, but don't know anything about it. Installation would be by a plumbing/propane company who did the furnace.
Any advice and suggestions on the install would be appreciated.
