New to this forum stuff but have a question. Waterline is 1300 feet from the municipal tap which is said to be wide open. We suffer from lack of volume and pressure. Is there a booster system I can add to allow me to increase my gpm and pressure?
Engineering firm designed a 3/4 iron pipe size tap which the ID is 5/8. They have the tap wide open. It would be costly to replace the line to a larger one but they are unwilling to change the tap size. Any suggestions?
It would be hard to draw more water from a 3/4 steel line. Either put in a larger line or use a cistern storage tank and booster pump. I didn't see anything about 100' in elevation? If that is the case a storage tank and booster is best as a larger line won't help.
we ran pvc for 1300 feet with several check valves in line and elevation rise of approx. 100 feet. Not to mention the engineering firm specked the wrong size taps (3/4 iron pipe size as opposed to 3/4 copper tube size).
Six-O
OP had 2 threads started on same topic.
