old-hill-billy
So some details first. 100' well, unknown 120v sub pump at around 80' hanging on 1" black PE, water level around 40'-50', all done in 2003. Above-ground well head, no pitless, going to a 20 gallon pre-charged pressure tank in the pump house, and a second pre-charged 20 gallon tank under the seasonal cabin about 150' away.
Per the graph, I'm dropping from 60 to 40 psi about every 6 hours or so, so basically losing about 1.5 gallons per hour to what I assume is most likely a leaking 1 way valve. Verified there are no leaks on anything above ground. It has been doing this for at least 2 years, I just hadn't hooked any instrumentation to it to know the rate until now.
So... If you were me, would you live with it, pull the pump and install a 1 way above the pump, or take the really lazy path and install a one-way above ground?
