BuzzSaw
I just joined (and donated). Forums like this one are valuable and I don't mind at all supporting them.
Here's my problem. I'd like to replace two toilets in my home. The replacement toilets require a 12" rough-in set back (although in my case the wall behind them is finished) and all I have is a 10" set back to the center of the 4" drain. The brass toilet flange is attached (leaded in) to a lead elbow, which looks like it's 90-degrees.
The only offsets I have seen are made of PVC or cast iron. Is there a way to attach an 2" offset of some kind to that lead elbow? I'm thinking whatever device I choose it would have to have either a brass or cast iron flange with an attached lead "skirt" that could fit inside the elbow and be leaded to it.
The easy answer would be to choose a toilet with a 10" rough-in and I would do that if I could find one with a "power flush" and/or a duel-flush option.
I'm not a plumber (but I worked as a carpenter for 13 years and I'm pretty handy) so forgive me if I used the incorrect terminology to describe things.
I'd appreciate any help you more knowledgable tradesmen/women can give me. Thanks in advance.
