Kitchen drain pipe connection
Still Learning
Sep 17, 2021
NC
Can you tell me if this setup right below the right side of the kitchen sink is a normal setup? I’m thinking it should have a straight piece coming down first. Also, would it require a slip joint washer?
Twowaxhack
Professional
Professional
Feb 9, 2021
8,948
3,902
United states
Those can be direct connect. It’s called a flanged tailpiece washer. I’m sure there are other names for it.
Still Learning
Sep 17, 2021
NC
So it’s optional to use the flanged tailpiece washer? When would I need to use the washer as opposed to not using the washer and doing a direct connect?
Thanks for your help thus far. I do appreciate it
Twowaxhack
Professional
Professional
Feb 9, 2021
8,948
3,902
United states
The washer is not optional. It’s inserted between the pipe and the sink basket drain.
All tailpieces and direct connect sink drains use a flanged washer or a washer of some type, it’s typically flanged.
