Is this a vent?
Discussion in 'Septic Tanks' started by Sh00tnBlanks, Mar 27, 2015.
  1. Mar 27, 2015 #1
    Sh00tnBlanks
    Sh00tnBlanks
    Sh00tnBlanks
    Mar 27, 2015
    Good Morning,
    I found a 4" PVC Pipe sticking out of the ground underneath my deck. Is this a vent or some kind of access point? Should it have some kind of vented cap or 180 degree elbow on it? It just seems strange to have an open pipe sticking up but I have no idea how a septic mound works. The pipe is about 5' away from the basement wall. It extends 34" above the ground. If I turn the sink on, I can go out and hear running water so I know it is connect to the line going to the tank. I've never noticed a smell or anything strange in that area. I'm just curious what its for and why it would be wide open.
    Thanks
  2. Mar 27, 2015 #2
    plbgbiz
    plbgbiz
    plbgbiz
    Professional Professional
    Jan 7, 2013
    161
    64
    It is the cleanout access for your building sewer. Cap it and create an access door through the deck. Someday you will be VERY glad you did.
  3. Mar 27, 2015 #3
    Sh00tnBlanks
    Sh00tnBlanks
    Sh00tnBlanks
    Mar 27, 2015
    There is a clean out located just inside of the building about 5' from the pipe that I found. Would it be normal to have two points that close together on the same line?
    My other question, if it is another cleanout that was just not capped properly, does it need to be three feet above the ground or could I cap it at a lower point and not have to rework my deck?
  4. Mar 27, 2015 #4
    plbgbiz
    plbgbiz
    plbgbiz
    Jan 7, 2013
    161
    64
    Cap it lower if you want, just keep it accessible.
    Cleanouts are like HP on boat motors. There is no penalty for having too much but it really sucks to not have enough.
    Sh00tnBlanks likes this.
  5. Mar 27, 2015 #5
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,797
    2,432
    the CO inside the building may be at a change of direction..
  6. Mar 28, 2015 #6
    Sh00tnBlanks
    Sh00tnBlanks
    Sh00tnBlanks
    Mar 27, 2015
    Thanks plbgbiz & frodo for the feedback. I'll stop by the hardware store and grab a cap on my way home today.
  7. Mar 29, 2015 #7
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    When or if your sewer line does backs up you probably you will probably not want to clean it from the inside clean out. :eek: That can be messy. If the one under the patio is accessible to haul equip under there than just cut it down and cap it. Another thing to look at is what elevation are the lowest fixtures inside the house in relation to the outside clean out. WHY? if you cap it and the sewer back up all the ay to your fixtures and that clean out is several feet below that, when you remove that cap, you better be quick or you will learn what a Plumbers baptism is. :D
Draft saved Draft deleted
Share This Page
Group Builder
