Irrigation pump
Discussion in 'Pumps and Wells' started by Chris, Aug 8, 2018.
  1. Aug 9, 2018 #21
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    It might. It is what almost every farm in the area has if they dont have a well. I'm going to look into my options
  2. Aug 9, 2018 #22
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    Aside from how I pick up the water what is a good brand of pump to look at? I need to start pricing things to see what's best for me.
    Also if I go with a well how can I keep driftwood and logs from killing this thing? The whole area floods.
  3. Aug 10, 2018 #23
    Valveman
    Valveman
    Valveman
    Pump Controls Tech Professional Lifetime Supporter
    Jan 6, 2010
    464
    92
    ,Lubbock, Texas
    My favorite would be a Berkeley like the B1.5ZPLS in 10HP with a 7 7/8" impeller trim. The little ditch over to the wet well pit is the best way to keep driftwood and stuff from washing everything away. Out in the main channel stuff can disappear on you. :)
  4. Aug 10, 2018 #24
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    I only sorry about it in the spring before I would put the pump in. The water can easily rise 10 feet so anything permanent can take a beating.
  5. Aug 10, 2018 #25
    Valveman
    Valveman
    Valveman
    Jan 6, 2010
    464
    92
    ,Lubbock, Texas
    A sub on a little trailer or skies would be good so you could pull it in and out easily.
  6. Aug 10, 2018 #26
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    That could work, I can get my tractor on the bridge and lower something down to.
  7. Aug 13, 2018 #27
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    I talked to the neighbor over the weekend and he is not going to let me dig a well near his bridge. He is already having issues with erosion and just said flat out no.
  8. Aug 13, 2018 #28
    Valveman
    Valveman
    Valveman
    Jan 6, 2010
    464
    92
    ,Lubbock, Texas
    Then maybe use two or three smaller pumps, so you could just throw them in the water by hand. Also smaller pumps need less depth to work in,
  9. Aug 13, 2018 #29
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    My irrigation supply house recommended a foot valve that sits inside a strainer. Us that an odd way of doing it?
  10. Aug 13, 2018 #30
    Valveman
    Valveman
    Valveman
    Jan 6, 2010
    464
    92
    ,Lubbock, Texas
    Not unusual at all. Just a 6" foot valve will need much more submergence than a 2" foot valve. A solid plate on the top of the strainer box will also help keep water from whirl pooling and sucking in air.
  11. Aug 13, 2018 #31
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    He is also recommending a 10 hp pump with a 2 inch inlet and 1-1/2" outlet to keep the pressure at 45 psi with 75 feet of lift through 4 inch pipe. Does this sound normal to you?
  12. Aug 13, 2018 #32
    Valveman
    Valveman
    Valveman
    Jan 6, 2010
    464
    92
    ,Lubbock, Texas
    If the pump has a 2" suction, you would want a 3" suction hose and foot valve. Same with the 1.5" outlet, you want to go bigger as soon as possible. What pump model number are you looking at? There are lots of different 10HP pumps.
  13. Aug 13, 2018 #33
    Chris
    Chris
    Chris
    Administrator Admin
    Jan 5, 2010
    8,832
    935
    Sweet, Idaho
    I'm waiting on him to get back to me and I will let you know
Share This Page
