Insulating 1” hepex??
europe72dead
Apr 7, 2020
74
10
New Jersey
I unfortunately have to run 1” hepex through an exterior wall. I do plan to insulate the 3.75” cavity but I also want to run insulation around the hepex as an added layer of protection.
I’ll first add R13 Kraft faced batts in the wall and the plan to use one of the two pipe insulators as well. Cost isn’t really a factor- I just want the best product for the job…
What do you suggest and why?
JG plumbing
Mar 26, 2021
1,443
512
Iowa
Fiberglass pipe insulation is what is used commercially. It works the best and comes in thicknesses as little as 1/2" up to 4" thick. We usually use 1"thick insulation.
Since your insulating the cavity your insulation probably doesn't need to be anything special. The bad thing about fiberglass insulation is the nasty itchyness. But it's the best.
Any one of the two you have posted would be fine. The long flex able one would probably be the easiest.
JG plumbing
Mar 26, 2021
1,443
512
Iowa
If your going with the rubber I think i would get as long of lengths as I could. Joining that stuff sucks and it doesn't stay together that well unless you use the proper solvent type glue proper insulation is tedious but is worth the savings.
PerplexedPlumber
Aug 9, 2020
177
62
64801
I’d use the rubber type, it’s closed cell.
There is a black polyethylene one that is closed cell and stiffer. There is a softer black one, more rubber-like, used a lot for HVAC pipe, and I didn't think that was closed cell. I think you are referring to the stiffer polyethylene type, right?
Twowaxhack
Professional
Professional
Feb 9, 2021
3,951
1,718
United states
I’m referring to the Armaflex in the OP’s post above.
