Installing booster pump for drip irrigation?
Truelight
May 21, 2013
10
I have a 1/2 acre of berries planted. My drip irrigation requires 23GPM (drip tube GPM/100' is .9 and I have 2550'). My well pumps about 10 GPM. I was considering installing a booster pump that pumps 30GPM but did not know if it was possible seeing how my well pump pumps less. What happens if you place a higher volume booster pump after a lesser volume well pump?
Thank you Thank you Thank you
Starting two threads on the exact same topic always causes confusion.
I would suggest you request to an admin that one be taken down, just my opinion.
I just did not know the best place to put it. I had no intensions to cause confusion. I'm just trying to find an answer. Thanks
I would consider installing a seperate well. Are you sure you're not going to dry your supply? That's a lot of water.
