pasadena_commut
Anybody know of a metal garden hose nozzle which is indestructible, adjustable, and serviceable? Also it should not put any lead into the water.
The most reliable I have found so far in a pistol grip is the Gilmour Full size zinc pistol grip. This one (but not a 3 pack):
https://www.amazon.com/Gilmour-Solid-Metal-Nozzle-Threaded/dp/B077GK1684/
These last a really long time, but eventually they get wonky at the spray end. Sometimes they spray backwards past the adjusting screw. I have never been able to fix one. For all I know it is just dirty inside the tube, or needs a new washer inside, but the plastic front plate seems to be pressed in, and the back adjusting nut is part of the handle and will not screw all the way off the threaded rod that runs through it. So no way to look.
What I would really like is a nozzle I can take apart and fix when it gets dirty. It doesn't have to be pistol grip, but that would be nice. The Gilmour's are cheap, but the local big box stores stopped carrying them (at least most of them did), probably because people were not coming back often enough to purchase replacements. This isn't a price issue, I would just like to stop throwing these nozzles away, and/or having them break at the worst possible moment.
Suggestions?
Thanks.
Suggestions?
Thanks.
