Identify Moen (?) valve
MPa
Jun 7, 2020
5
Montreal, Canada
Hi!
Here's the inside of the valve I have right now. I'm pretty sure it's a Moer (there's an M engraved). Does anyone know what this is or what it would be compatible with?
Thanks!
@breplum OK, here it is, but inserted. Is this good enough, or should I pull it out? Do you need to see it from the side as well?
Hi, that is not Moen, Delta, Pfister.
Picture of back side of the cartridge, the cover parts and the plate.
You need to provide as much info as possible
Here's the plate. Pretty generic look to it :)
Thanks for your help.
Revealing the part id sometimes helps.
That mfr name doesn't show up in U.S.
glad u found it.
