Identify Moen (?) valve
MPa
Jun 7, 2020
5
Montreal, Canada
Hi!
Here's the inside of the valve I have right now. I'm pretty sure it's a Moer (there's an M engraved). Does anyone know what this is or what it would be compatible with?
Thanks!
MPa
Jun 7, 2020
5
Montreal, Canada
@breplum OK, here it is, but inserted. Is this good enough, or should I pull it out? Do you need to see it from the side as well?
breplum
Professional
Professional
Nov 14, 2017
447
152
Lafayette, CA
Hi, that is not Moen, Delta, Pfister.
Picture of back side of the cartridge, the cover parts and the plate.
You need to provide as much info as possible
breplum
Professional
Professional
Nov 14, 2017
447
152
Lafayette, CA
Revealing the part id sometimes helps.
That mfr name doesn't show up in U.S.
glad u found it.
