Identification of residue on pipe.
Discussion in 'General Plumbing Help' started by Mahoogan, Jul 12, 2019.
  1. Jul 12, 2019 #1
    Mahoogan
    Mahoogan
    Mahoogan
    Jul 12, 2019
    TN
    Hello, I noticed the residue in the attached image on a pipe in a crawlspace. I could only see a few feet of the pipe exposed and didn't notice any other areas with similar characteristics.
    Has anyone seen this before and know what the likely culprit is? I'm curious if it is corrosion resulting in a small leak.
    Thanks
  2. Jul 12, 2019 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,433
    211
    Boston, Massachusetts
    if that's your drain its rotting out the culprit is age.....
  3. Jul 12, 2019 #3
    Mahoogan
    Mahoogan
    Mahoogan
    Jul 12, 2019
    TN
    Thanks. I was afraid of that.
  4. Jul 13, 2019 #4
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,433
    211
    if your at all handy you can change it its just very dirty the cast iron is probably very thin so you could cut it with a swazall and the correct cutting blades change as much of that pipe as possible if its all the same age its propabley close to the same condition you can use pvc in its place with the proper transition couplings
Share This Page
