I cannot determine drain clevis clip size online...
herkdrvr
Feb 27, 2016
16
Hi All,
I was clumsy and lost the clevis clip to a drain. I bought one locally and it's ~1/4" but the actual rod itself is 1/8". Are there any manufacturers who make a clip with a 1/8" opening? I found Danco 34807 on Amazon and they say "small hole" but not sure what the diameter is.
Any help appreciated.
Thanks!
~Herk
Am I the only one who has used a rubber band for this function? Wrap it around the rod a few times, put the rod thru the lift arm, and wrap the same rubber band around the rod on the other side of the lift arm. I used it in a pinch once on one of my rentals. And it worked fine.
Looks like if the recommendations are DIY sheet metal clips and rubber bands that this clip doesn't exist.
Oh well. Thanks anyway.
