How was this older style of drain pipe typically held in place in the floor?
mrblint
Sep 2, 2019
PA
I need to replace an old drain pipe (late 1940s, early 1950s) which goes into a stub coming up through the tiled floor. The flange that screws down onto the trap has corroded and crumbled into small pieces. The drain pipe that fits into the stub pipe in the floor won't budge and I'm afraid to put much torque on it. The former owners of the house did not remove the tile floor but tiled on top of tile. Is it possible there's a set-screw holding the drain pipe in place in the stub pipe, which is now hidden below a layer of floor tile? How were these pipes typically held in place? Is it just a caulk or plumbers putty seal? Any special solvents available to loosen it up, if so?
TomFOhio
Professional
Professional
Jan 20, 2018
1,092
229
Mansfield,, Ohio
Its hard to tell but it looks like the pipe is soldered in. You can cut the chrome pipe a few inches above the brass
piece and put a slip nut adapter there and then replace the rest of the chrome pipe. You can replace it with pvc
if you want or stay with chrome.
Jeff Handy
Jul 5, 2019
1,675
290
Chicago suburbs
A slip nut adapter would work, but might be kind of wobbly.
This would give you a sturdier connection to a new section of pipe, after you make a cut three or four inches above the stub coming out of the tile.
https://www.amazon.com/American-Valve-RNH40-No-Hub-Coupling/dp/B00SVYT6P2
This link is just to show the type of coupling.
Other companies, Fernco for example, also make these rubber couplings with a sturdy clamping system to support it.
TomFOhio
Professional
Professional
Jan 20, 2018
1,092
229
Mansfield,, Ohio
Jeff, those couplings won't work on tubular pipe. If the slip nut adapter coupling is put on correct
it will not wobble. Sometimes you have to use them.
Jeff Handy
Jul 5, 2019
1,675
290
Chicago suburbs
As long as he is re-doing it, maybe he should add an air admittance valve, because he has an old S trap.
