How to protect buried black steel pipe
whoru9999
May 7, 2010
5
I have very little experience with gas line piping. I just had a Yellow PE gas line ran to my pool heater by a pool contractor. It terminates near the pool heater with what appears to be a compression fitting that is connected in turn a black steel elbow and a short run of black steel pipe. The compression fitting and elbow are buried undergroung (wrapped in protective tape) and the pipe comes up out of the ground to my heater through a valve.
I would like to extend the run by about 48 inches because I have to move my heater. I would like to remove the elbow, and use a black steel pipe length. I have the protective tape (American Presto Pipe Wrap Tape), and plan on wrapping the pipe and fittings, then coating the whole thing with roofing tar. Should this provide enough protection to last for quite a while?
Personally I would use copper or CSST (Corrugated Stainless Steel Tubing). Both are approved for underground use and will last a very long time.
So...still looking for an answer about the black pipe...Is there a better way to protect it than what I planned on trying?
Some municipalities strictly forbid any metal gas pipes to be buried underground. Also, most municipalities demand that any and all gas pipe be buried between 12" and 24" below grade. Sure, it's your backyard and could do anything you want, until something bad happens. The problem is that if something bad was to happen, you might find out an insurance company will deny any and all claims against incorrect workmanship. Added to this is the fact that if and when you sell your home, and inspector will order this pipe to be corrected before you could sell it.
OK, the above is my disclaimer. You have a few choices. My preference would be to dig the original yellow pipe down to it's horizontal depth, and have a licensed plumber with the correct equipment add the needed 4-5 feet of yellow pipe. They use hot blades, and basically weld additional plastic pipe to extend the length desired. It is also not too costly. I paid my licensed contractor an additional $75 to branch off my yellow pipe so I could add a BBQ in a pre-designated location.
If you choose just to run the black pipe, I would wrap the hell out of it, but leave off the roofing tar. The reason for this is because some chemicals cause metal pipes to break down quicker, and since roofing tar is not designed for the purpose you are using it for, nobody will know for sure if you are causing more harm than good. There is also an epoxy available, but I'm certain you would have to ask a professional where it is available, and probably not a "big box" stocked product.
Just understand that I am not a licensed professional plumber. I am an old handyman who cares about what he does, and is not afraid to call in a professional when necessary. They spent months and years learning their profession, and could do dances around some of my knowledge.
Good luck with this project, and I apologize for my long winded reply, but it just seems necessary at times!
Thanks for the reply. Everything up to this point has been inspected by our village and has passed, but I appreciate the disclaimer. I will forgo the tar and use the pipe wrap, just to get me through for a while. I probably will get a plumber to do the PE work some time in the future (the fall). I just want to get the pool up and running, and so far the gas line has been a real pain. The installer only went about 6" deep, and I had them come back and redo it for 18". They weren't real pleased.
You live in a village? Have you seen M. Night Shyamalan? :eek: Just kidding! One item I forgot to add is make sure you continue the ground identification wire all the way up the new pipe, and connect it in a way that it will not corrode over time.
Hi, just curious what you ended up doing here and if you had any success with the roofing tar if you used it. If you used the roofing tar, did you put it under or over the pipe wrap tape? Do you remember what type of roofing tar you used and how long did you have to wait for it to dry? Thank you.
