So, here I am, joining yet another forum bc I'm stumped. My name is Alex, long time reader, first time poster. As a homeowner and single mother, I've learned so much online about things so far beyond my lady brain and I am so proud of myself. But I need help yet again. I'm clearly not a plumber and I'm at a fork in the road here. What should I do to cause little to no disaster?? Thanks for reading.
Ok. my toilet started leaking at the floor the other day, no problem I've got this. Not my first rodeo. Have the extra parts to replace the fill and flush valves and the gaskets. Cool. Decided to use a waxless thing, seems good since I know myself and will have to pick up and reseat the toilet anyway.
Cut to, me lifting the toilet off the floor. The pvc flange(I'm assuming a drop in extender thingy?) Is cracked. "Why would that be?" I ask myself. That's strange. So I clean up the wax and whatnot, put my new bolts on and notice the lazy tile job that had been done. Unless I'm wrong then my apologies to the tile guy. But as you'll see in the photo, the flange isn't able to be flat and level bc said tile isn't cut back far enough. Right? "Whatever, it was fine before it'll be fine again" I tell myself. Put the bolt back in, seat and reseat and reseat the toilet again. Got it. Ok tighten the bolts back and forth, back and forth. CRACK. " **** me.. " I knew it was the flange, however, toilet wasn't rocking(it wasn't rocking before this either) so I continue on with the install. Everything is good, turn water on and no leaks. Yesss
But I can't stop thinking about the geyser of **** water it'll become, sooner or later. So, I go get a flange repair thing, undo all my previous days work, go to put the thing on and I can't. The tile is too close. I want to just grind it away from the flange, finally having a flush and level base, but I'm second guessing myself. Is that the right thing to do? What do I do?? Please talk me down or tell me I'm right. Either way, I need advice, criticism, something. Lol any feedback is welcome. Please and thank you.
P.S. I have removed the bolts to this thing bc I was gonna take it off. Then I decided to ask for help.
