Hello All, I recently purchased a home with a well and septic system (starting to question this decision). This is all new to me and would appreciate it some of you can answer some questions. Thanks in advance.
I have this stagnant water, swamp, bog type smell in the home that I cannot trace. I suppose it could be a sewer smell, but I have always associated a sewer smell with raw sewage, which is not what this is. I haven’t actually moved in the home yet, but stop by several times a week and notice the smell as soon as I enter. The sellers had a well/septic inspection in October and everything was good as it relates to bacteria, nitrate, etc. I took possession a month later. I’ve also had the septic system pumped.
The smell is fairly faint most of the time, and other times a bit stronger, but always noticeable to some degree. If in the home for some time a while, I kind of forget about it. Kinda like that Febreeze commercial where you can’t smell the odors in your home. But when I I go in the family room it is sometimes stronger there. With the exception of the laundry, that’s the only room that’s underground. The only other odors exist if I use the washing machine. The laundry room turns into a hot bucket of rotten eggs. But no odor in there otherwise.
I’ve tried to trace the smell to the sinks/showers, toilets drains and even the crawl space, which houses the pipes, tankless water heater and pump, but I smell nothing in those areas. On occasion, the kitchen water also has that sulfur smell, but barely noticeable unless you are really sniffing for it.
Any suggestions on what could be the problem will be greatly appreciated. Thanks, Connie
