IHatePlumbing
Hello - another day, another plumbing problem.
I had some plumbing work done recently and now I'm almost completely without hot water. I had a small section of galvanized pipe replaced at the main water entry point (before water heater) and also some flex pipe at the water heater replaced with hard copper piping. The expansion tank was corroded, and needed to be replaced, but the plumber didn't have the right one at the time, so he piped it without the expansion tank while a new one was on order. Everything was working fine after this. Plumber came back and put in the expansion tank and we've not had reliable hot water since then. Plumber came back out and said everything looked fine and advised me to call manufacturer of water heater. I got a new water heater in 2017 (50 gallon Rheem gas water heater). I called Rheem and they had me turn off the inlet valve to the water heater and turn on the hot water valve on a nearby faucet. I let it run for 5 minutes and it flowed very fast, but was not hot. Rheem said that the fact that water still continued to flow means that there is a problem with the plumbing. Also, all status lights on the water heater suggest that it is operating normally. Plumbers are coming back out, but they don't think it's a plumbing issue from the work they did. They want to check every fixture in the house to see where the water could be mixing. I found it interesting that the plumber held the outlet pipe at the water heater and could tell that it was at 70ish degrees.
I'm including some pictures of the piping at the water heater. Any help or suggestions?
Thanks,
Brian
Thanks,
Brian
