Justinwayne
Hi everyone. I have a question dealing with my garage bathroom. I built this bathroom using 1/2-inch pex piping. The pipe comes into the bathroom, the first drop down is to the sink, the second drop down is to the toilet, and the third drop down is to the shower. When i constructed the bathroom, I connected the pipes from the old washing machine connections for the hot and cold water, since I did not want to cut the water lines in the house. I get really good water pressure in this bathroom. In order to get hot water in the shower I had to turn up the gas hot water heater all the way to very hot. The sink had nice hot water, but the shower needed the higher setting to have hot water. Recently I installed a Rheem 13 Kw tankless water heater just for this bathroom. Now the problem: I have the Rheem set to 140 degrees. The sink is 140 degrees when I run it. When I run the shower i just get lukewarm water with the sink not running. When I flush the toilet, I get hot water until the toilet finishes filling the tank then back to lukewarm. I even turned off the cold water and just ran the hot the same thing goes. I thought it might be the shower valve, so I changed that out. I built this bathroom about 7 months ago that is actually when i change out the valve. Maybe I should change out the valve again? I hope someone could help me with this. Any theory's would be welcomed.
