Hot water coming through cold faucet
Discussion in 'General Plumbing Help' started by JohnBay, Mar 17, 2018.
  1. Mar 17, 2018 #1
    JohnBay
    JohnBay
    JohnBay
    Mar 17, 2018
    Hi, I just had my basement bathroom remodeled and now I have anywhere from Luke warm to hot water coming through the cold faucet in the sink. It does get cold at times but will get warm again. The shower which is a new single handle moen Adler, has hot water around 108 degrees on full hot setting then after a minute is cools down to around 80s. If I turn the shower handle to the cold side and wait a minute and turn it back to hot, the water comes out hot again for a minute and goes right back to cool again. All of my water fixtures in other rooms do not have this problem. They all work fine. Now I read about Moen having this issue with the cartridge so I got a new posi temp cartridge and seemed to fix the problem after it was working for about 5 min after install. Now I go downstairs and try it again and it's back to the same problem. Even before the remodel, my water heater had been leaking from the t&p valve about 2 gallons every other day. I put a new valve in and it still drips but only a few ounces a day now. I did notice the cold water inlet into the water heater was hot at one point but it is cold now. I had a leak in the bathroom shower plumbing but my contractor put new piping in. I don't know what is causing this issue. If anyone has any idea I would appreciate any help. Thank you
  2. Mar 18, 2018 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    571
    76
    Boston, Massachusetts
    if its a single handle faucet shut off the water under the sink then check the shower sometimes single handle faucets will cause that
    ok that rules that out
    if you just had it done have you had the plumber back???? if there were no problems before this its something that happened during the remodel
    like the other poster says before the relief valve really leaks either lower the temp if its to hot or replace
    the t/p valve
  3. Mar 18, 2018 #3
    JohnBay
    JohnBay
    JohnBay
    Mar 17, 2018
    The sink is a double handle and shower is single.
  4. Mar 18, 2018 #4
    Matt30
    Matt30
    Matt30
    Jan 17, 2012
    2,000
    776
    Halifax, Nova Scotia
    OK are you just going to ignore the t&p on the water heater? They drip for a reason.
  5. Mar 18, 2018 #5
    JohnBay
    JohnBay
    JohnBay
    Mar 17, 2018
    It's not dripping now.
  6. Apr 24, 2018 #6
    pcride
    pcride
    pcride
    Oct 16, 2013
    94
    13
    What’s yer water pressure
  7. Apr 24, 2018 #7
    CT18
    CT18
    CT18
    Apr 30, 2014
    296
    70
    Bloomfield Hills, Michigan
    I would say you have a pressure issue and it is causing a mixing issue in one of your fixtures. These fixtures are not rated for higher pressures especially the washers.
  8. Apr 25, 2018 #8
    wood4d
    wood4d
    wood4d
    Active Member
    Apr 1, 2014
    26
    do you have an expansion tank on your hot water heater? if its bad the t and p will leak
  9. Apr 26, 2018 #9
    worahm
    worahm
    worahm
    Aug 26, 2016
    10
    Is there any possibility the tubing for the cold water facet was routed though your attic? My neighbor had leaking issues with tubing that was run under the cement slab when his house was built . He had the entire house re-tubed with plastic tubing. Much of the new tubing was run though the attic, Depending on the time of the year, he has warm water running from his cold water facets.
  10. Apr 26, 2018 #10
    worahm
    worahm
    worahm
    Aug 26, 2016
    10
Share This Page
