horizontal wet vent mock up, Please advise
Discussion in 'Project Display' started by bartleyhs, Feb 2, 2020.
  1. Feb 2, 2020 #1
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    I will be ripping out my previous attempt at this per Frodo’s suggestion. Here is the mock up for my new plan. I will be doing a horizontal wet vent for the bathroom group and kitchen sink. I would appreciate feedback from the pros. (I promise if you help me through this I will never attempt this on my own again.)
  2. Feb 2, 2020 #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,803
    2,433
  3. Feb 2, 2020 #3
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    Thanks Frodo.
    Now I am going to ask a couple of “why” questions. Please dont take offense. I’m not questioning your expertise, just need the whys and whatfors to be able to understand and learn
    #1 Why the extra pipe to take the WC all the way to the sink vent and back rather than what I have. Is it for accessibility (less is in the wall and more in the crawlspace)?
    #2 I see what you’re saying about the tub drain, but doesn't this now create a dry horizontal vent under the floor? That’s not allowed is it?
    #3 you have the WC connecting after the kitchen sink. That makes sense because I’ve seen a lot of posts in these forums that say the toilet always goes at the end. My question is that the florida code says any fixture not part of the bathroom group has to connect down stream of the group. I will attach it, it is very possible I am not understanding that correctly.
    Thank you for taking the time to help me with this.
  4. Feb 2, 2020 #4
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    By the way, I realized it might be helpful to have the picture showing where the vents/walls, etc are. Its not exactly to scale but its a basic representation of where things are located. DE158BDC-FEDF-408C-8A6B-667E76C01118.jpeg
    I dont know why the mock up is showing up here, but I cant get rid of it.
  5. Feb 2, 2020 #5
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,803
    2,433
    Because what you have drawn is illegal. On a vertical the vent is on the top, the way you have it. when the toilet flushes the vent is cut off because of the water.
    It is perfectly legal, as long as the vent take off is rolled so the vent is above the water/bottom of pipe
    Reread the code you posted
    It says. Only the fixtures within te bathroom groups shall connect to the horizontal BRANCH drain.
    the Branch begins at the combination off of the building drain.
    look at it like a tree, the main or building drain is the trunk
    the line going to the bathroom is a branch
    you did not draw in the existing vent it needs to tie into the building drain
  6. Feb 2, 2020 #6
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    Thank you for taking the time to explain.
    Does this fix the toilet / Lav connection?
  7. Feb 2, 2020 #7
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    [you did not draw in the existing vent it needs to tie into the building drain]
    The existing vent (that penetrates the roof) is the one by the tub. This was why I did the convoluted hook up at the tub drain because I was thinking there had to be a fixture connected before the vent stack to keep a portion of the horizontal pipe from being dry. This is what I was trying to avoid.. Am I wrong about this being a problem?
  8. Feb 2, 2020 #8
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,803
    2,433
    Your location says Oregon that is UPC code
    you said in your post you are in Florida, that is IPC
    706.4 Heel- Or Side-Inlet Quarter Bends
    Heel-inlet quarter bends shall be an acceptable means of connection, except where the quarter bend serves a water closet. A low-heel inlet shall not be used as a wet-vented connection. Side-inlet quarter bends shall be an acceptable means of connection for drainage, wet venting and stack venting arrangements.
    use a tee. not that low heel
  9. Feb 2, 2020 #9
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    My permanent address is Oregon. I am in Florida working on a tiny old house we bought when my husband was stationed here (Navy). The tenants moved out so I came back to get the house ready to put on the market. So yes IPC is what we’re dealing with here. Its not a typical flip though. I am taking my time and trying to make sure its all done correctly. I moved the lavatory from one side of the room to the other and that seems to be what has caused the venting issues.
  10. Feb 2, 2020 #10
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    Got it. I will change out the WC/ lav with a tee.
    Now for the tub side where the main vent stack is. Can I do the same thing there with a tee on the vertical vent? Like this..
  11. Feb 3, 2020 #11
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,803
    2,433
    yes, you can
  12. Feb 3, 2020 #12
    bartleyhs
    bartleyhs
    bartleyhs
    Jan 18, 2020
    23
    oregon
    That’s great and will make it a lot easier.
    Thank you SO much for your time. You have been more than generous sharing your knowledge.
    I will let you know how the inspection goes.
Draft saved Draft deleted
Share This Page
Group Builder
