highrocklaker
We have a masonry boathouse that has a flat cement roof. Water will often pool on top of this roof. There is a drain on top of this roof, covered with a flat metal screen, and it drains into some 1.5" PVC pipe that runs vertically through the masonry, then across the ceiling on the interior and then back down and out the base of the masonry. The piping was clogged with debris and I've replaced the PVC and it is now clean and free of obstructions. However, during heavy rains, the water will cover the top of the drain and then no water will exit the drain. I'm assuming that I need to modify the piping to ensure air can enter the drain -- is that correct? If so, what's the best way to introduce air into the piping? Must air be introduced at the top of the drain run or can I install an aerating valve anywhere in the piping? Thanks in advance for your advice!
