DIYHELP
Hello and thank you in advance for the help.
Needed: Shower pan size 36 x 36 with drain exactly in middle
Cast iron pipe is 1/2 inch below top of subfloor.
Can not get underneath to plumbing
What are my options for a shower pan. It seems it is difficult to find a shower pan with drain exactly in middle of pan. The only one I can find is the 3636M(Mustee) and it is has the integral molded drain and requires the pipe to be even with sup floor top, so the pipe would be low in the molded drain i the 3636M.
Should I be chainginng the cast iron to PVC?
In the end how will i ever know if drain is sealed or not if there is no access below
Please see pics.
Any suggestions would be greatly appreciated.
Thank you.
DIYHELP
Please see pics.
Thank you.
DIYHELP
