Help with identifying Symmons part numbers
Discussion in 'Showers and Tubs' started by Swerve, Jul 15, 2015.
  1. Jul 15, 2015 #1
    Swerve
    Swerve
    Swerve
    Jul 15, 2015
    This is my Symmons model M safety mix. It stopped giving me reliable hot water pressure. Needs a new spindle for mixing. To my dismay this isn't a ta 10 which every hardware store carries.
    I also bent the spindle cap a bit because I didn't heat it. So I need that too ...
    Any assistance if identifying the part numbers would be great. The house that it came with was built in 1957. This is likely original to the year of the home build.
  2. Jul 16, 2015 #2
    Swerve
    Swerve
    Swerve
    Jul 15, 2015
    A reply from Symmons for those who find this on the web and are in my Situation! Any feedback is still very welcome !!!
    Hello,
    Thank you for your inquiry. This unit actually looks a bit older than the Model M and is a Mono-Mixer. While this valve is obsolete and out of warranty, you can replace the internals using Safetymix parts. The parts necessary would be a:
    C-5 (spindle)
    SC-2 (cap)
    SC-3 (seat; this also requires the C-50 tool)
    RC-14 (handle)
    These would work in that valve, but all need to be replaced together as the current parts won't work with these.
    Mr_David and Caduceus like this.
  3. Jul 17, 2015 #3
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    3,868
    930
    Santee,Ca,
    Thanks for the update. Sorry nobody here had the answer for you.
  4. Dec 16, 2017 #4
    LeahM
    LeahM
    LeahM
    Dec 16, 2017
    Swerve,
    I also have an old mon-o-mixer that is dripping and needs to be repaired. Once I found out it was discontinued I was debating whether I should invest in updating the valve and getting something modern. But I'm not sure if that would be costly:confused::confused:
    Did the safetymix parts work or did you wind up doing something else?
    This is what I have:
  5. Dec 18, 2017 #5
    Swerve
    Swerve
    Swerve
    Jul 15, 2015
    Hey friend. Wow itÂ’s been a awhile since this post. So I ended up finding the parts and doing the update. It worked. I ended up making my own c-50 tool as well.
    Good luck. Those parts came in some old packaging, and from a source in Brooklyn.
Share This Page
