Brian McNamara
Hey all,
I am trying to build a carbonator using the Mccann carbonator but struggling to figure out how to hook things up.
The water out is a 3/8" female flare fitting, I want to tie this into a keg tap (via a tap shank with a 3/16" barb fitting). I was hoping to find a 3/8" flare to 1/4 barb (stainless steal since copper and brass will leach), get some braided PVC (or other pipe) and clamp them down. However the only thing I have been able to find is: https://installationpartssupply.com...-Elbow-90°-Radius-Stainless-Steel_p_6459.html which I don't really need the 90 degree elbow.
I'm hoping there is someway I can make this work, please let me know if you would change something about the design or if you can help recommend parts for this.
Thanks in advance!
Thanks in advance!
