Attempting to replace my toilets stop valve.
I took the old one off (which appears to be threaded). I purchased a compression 1/2 inlet to replace.
Problem is, when I tried to put the new one on it was too small. Nither the nut or the brass ring would fit over the pipe. I took and angle grinder and cut off the threads thinking that was the issue but they still won't fit.
I don't see any shutoff valves with inlets larger than 1/2 being sold... so I'm superrrrr confused. Please help.
