oneBlessedMan
I’m new here but I’m in need of some serious help. My drains keep backing up and I know it’s because the drain pipe is not graded out because they have fallen down towards the middle of the house over the years. So, I’m going to replace them. I have attached a picture of the culprit.
Anyway, it looks pretty straightforward, but I’m sure there’s a better way to route everything. Also, I’m concerned that when I remove/cut the pipes then the vent tube will fall down. I need to keep that where it’s at until I can reconnect it (see second picture).
Any advice here? Thanks!!
