Diehard
In Remembrance
The fact of the matter is that the pump, along with the 2" piping are erroneously oversized for the application. Obviously!
Granted it should not have been piped to the drain of another sink. A simple fix for someone else's mistake.
The codes do not cover every scenario and application, as many should know.
A centrifugal pump actually requires less HP as you climb higher up the performance curve at higher heads with less flows.
You can speculate all you want but when and if that pump goes, and they all do eventually, it can be replaced with a small grey water sump pump, which are becoming more common for use with laundry sinks in basements and the like.
In the meantime, if he puts aside a dollar a day for a year or so, he still wouldn't have enough to have a plumber come in and do it right.
Give the guy a break. He was looking for a quick fix and has it.
If you think it's worth doing it right, go do it for him.
EDIT: It's also against code in most states, to do plumbing work without a license. But that subject never seems to get mentioned as far as not meeting code.
