Help needed with new shower head idea...
Discussion in 'Showers and Tubs' started by hippychop, Jun 11, 2019.
  1. Jun 11, 2019 #1
    hippychop
    hippychop
    hippychop
    Jun 10, 2019
    5
    Jacksonville, FL
    Hi everyone,
    Just joined the forum in hopes of getting a little help with my shower situation. I want to install a new shower head in my guest bathroom. Since the shower is fairly small, I think a shower head like the one pictured below that streams the water from directly overhead will be best. My problem is that the plumbing is not at the correct height for this. I'm trying to avoid removing the tile and extending the plumbing to the correct shower head height. Is there any way to install a new shower head with and waterfall type head with my current plumbing? Thanks for any help.
    - Mark
  2. Jun 11, 2019 #2
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    983
    211
    Mansfield,, Ohio
    The picture you have at the bottom is what I was going to suggest. You could do it exactly like the picture
  3. Jun 11, 2019 #3
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,196
    370
    North Reading, Mass.
    When you say, "that the plumbing is not at the correct height for this", were you referring to shower head height vs the height of your hose connection?
  4. Jun 12, 2019 #4
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
  5. Jun 12, 2019 #5
    hippychop
    hippychop
    hippychop
    Jun 10, 2019
    5
    Jacksonville, FL
    I am referring to the height between the center of the handle and the center of the shower connection shown above. The distance between these two is 7".
    The distance between the two wall mounts for this bar seem to be roughly 20" apart. I was assuming the top mount of the new head would connect to the water outlet and the bottom mount connect where my on/off handle is. I'm not sure why they put the pipe only 7" above the handle in a standup shower? Ideally I would like to install the new head shown above, just not sure how I would do it with the short distance between my handle and my shower head pipe. Hope this helped explain things better. Thanks for taking the time to help me out everyone.
  6. Jun 12, 2019 #6
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
    That is a handy cap shower
    the hand held is low so it can be accessed by a wheel chair bound person
    it is not correct..but that looks to be the intent
    to install the item you posted
    remove the existing shower head , nipple,
    install the new unit
    the shower extension you are showing is not one piece, it has several parts
    if you would post a link to the actual item..we can go over exactly what you gotta do
  7. Jun 12, 2019 #7
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
  8. Jun 12, 2019 #8
    hippychop
    hippychop
    hippychop
    Jun 10, 2019
    5
    Jacksonville, FL
  9. Jun 12, 2019 #9
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
    weird..it is at the top
    have you looked for a bottom fed unit?
  10. Jun 12, 2019 #10
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
  11. Jun 12, 2019 #11
    hippychop
    hippychop
    hippychop
    Jun 10, 2019
    5
    Jacksonville, FL
    I'm not having any luck finding a bottom fed unit. I did find some shower risers, although the tops of the ones I found might not reach out far enough over the shower to mount the rain head directly above where it needs to be. The more I look around, it seems like it would be easiest to just put something together myself with elbows and pipe.
  12. Jun 12, 2019 #12
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
    https://www.supplyhouse.com/Bluefin...ping&msclkid=9ce3a11dd21812de3fc2fc1cd57d75d2
    you can buy chrome pipe and elbows
    also the wall to pipe brackets
    you will need a wrench called a strap wrench so you do not mar the chrome
  13. Jun 13, 2019 #13
    hippychop
    hippychop
    hippychop
    Jun 10, 2019
    5
    Jacksonville, FL
    frodo likes this.
  14. Jun 13, 2019 #14
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
  15. Jun 13, 2019 #15
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,759
    2,404
  16. Jun 13, 2019 #16
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    325
    85
    Pluck yeah! Except I’d use powered actuators with a remote control!
  17. Jun 13, 2019 #17
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    325
    85
    Oh yeah, there’s no bottom fed units, these are designed as retrofit units to mount on a standard shower head outlet.
  18. Jun 13, 2019 #18
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    983
    211
    Mansfield,, Ohio
    Our Menard's flyer has a Delta shower hose and spray wand that you can hook to the nipple coming out the wall
    and then there is a slide bar that you can slide the shower wand as high as you want. It's $19.99.
Draft saved Draft deleted
Share This Page
