dmaxweb1
Hi All
New on this forum and looking for advice
When my house was built the plumber routed the pump 2" discharge into a wye on the side of the 4" gravity drain rather than the top. Will this be problem? There is not room to cut out and replace the wye fitting. I could cut the pump discharge pipe right before it enters the wye and use 45 fittings to raise above the height of the gravity drain. Or, should I just not worry about it? There is a check valve in the 2" pump discharge.
Thanks
Thanks
