[Help]Bathroom shower enclosure popped out
niterid3r
Jul 6, 2015
6
Hi all,
This morning the shower door popped out from the enclosure and i noticed that happened due to the over head enclosure pipe that connects to top and bottom door hinges was out of alignment.
When closely looked at that pipe found that it has rubber inside the pipe which is probably used to grip the pipe to the glass.
I have put the pipe rubber together to the enclosure and it is aligned back to the way it should be. However, it is not really firm.
The question is that do plumber use any adhesive agentto stick the inside rubber and pipe to hold the glass firmly?
If so then what is the most suitable one for these type
Thanks
