Lynn Thomas
- Joined
- May 7, 2023
- Messages
- 1
- Reaction score
- 0
Hi-
I have a Grohe Arden shower faucet. The handle assembly has become loose and I would like to tighten it up. However, I can't figure out how to remove the handle to access the internal set screw. By looking at the drawing of the faucet, the front button should come off to expose a screw that would allow the handle to come off when the screw is loosened. I've tried using dental floss and fishing line to create a seam between the button and the main handle but that hasn't worked. I've tried using CLR solution to free any minerals that may be impeding getting the button off but that hasn't worked either. Any advice from the forum is most appreciated.
