plumber_not
Hi all,
First time poster because this is driving me crazy. I have a leak somewhere, but I cannot find it.
How do I know? I have a smart water valve that alerts of certain flow conditions and my smart water valve has been telling me that I have low-flow leak, everyday, since Oct 2021 (8 months now)! I've done everything I could to try and find it. I do not have a complicated or huge plumbing system.
Here are some facts:
-house was built in Aug 2017 up to date (for Canadian standards)
-I have photos of when the house was being built: all the pipes are in the floors/ceilings, and rarely in the wall, except for the basement washroom, the toilet and sink pipes are in the wall (built-out plumbing wall). why this information is important will come later
-the leak ranges from 0.5 to 0.7L/hr or about 15 to 20L a day
-when I close the main water valve, within 5 to 10 seconds, the smart water valve leak conditions correct itself and says the leak has been resolved (see photo)
-the utility meter, also shows a small leak (small dial turns a bit, every few seconds, see photo)
- I've used the ink in my toilets tank, not leaking toilet
- the smart meter water valve alerts me of low flow condition when water flow is detected for more than 2 hrs, and then it tells me that the condition is resolved if the water stops flowing for more than 5 seconds or so. I get multiple warnings everyday because it flows and then resolves itself repeating this cycle all day long, for 8 months now ..so it doesn’t seem to be a continuous leak, but its present every day, but at times it can go for 16 hrs straight, but never continuous.
- just last week, we went on vacation and turned all the valves off either near/at the receptacle (i.e. vale under the sink or toilet) and at the mechnical room (but I did not turn off the main house valve one), to determine where the leak could be;
At this point, the only thing that has water is
-3 showers/bathtubs (which are bone dry)
-fridge water/ice maker
-hot water tank (with recirc pump and line)
With all those valves off, we were away for 7 days and I lost 100L of water
Next, you might think there is a leak somewhere in the pipes/lines. I must say, there is no evidence of water in my walls or ceilings...since October of 2021, I would hope by now, it would show itself, especially considering its around 20L/day, but nothing out of the ordinary in my walls or ceiling.
I even used a thermal camera back in November and December (cranked up the furnace to high temperature) and found no unusual stains or spots in the drywall/ceilings (mind you, I’m not an expert in thermal imaging).
So, now i don't know what else it could be? I suspect the water is going into a drain because I see no evidence of water damage in the walls/ceiling over the last 8 months, but I have no idea now.
I suspected the hot water tank was leaking through the condensation tube, and into the drain. I was thinking of isolating the hot water tank for a bit, to see if the leak stops (I haven't done this yet).
Any help or input would be greatly appreciated. Please let me know if you have any questions about my home, I would be happy to answer them!
- all 4 toilet cold lines off
- all 4 bathroom/washroom sinks cold and hot off
- humidifier
- washing machine (hot/cold) and dryer steamer lines (cold)
- outdoor hose bib lines (2 colds) - valves in mechnical room
- garage sink (1 cold 1 hot line) - valves in mechnical room
- Kitchen sink off (hot/cold)
- dishwasher
