Ghost Flushing
Discussion in 'Toilets and Sinks' started by RetiredCarGuy, Feb 2, 2015.
  1. Feb 2, 2015 #1
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Keeping It Simple Retired Guy
    Feb 2, 2015
    10
    , New York State
    An American Standard one piece toilet is particularly difficult for me to correct. It ghost flushes about every 2 to 3 hours. Sometimes more, sometimes less. A new Fluidmaster Pro45 was installed and also an AS flapper disc.
    Any advice from those that may also have encountered this. Thanks!
  2. Feb 3, 2015 #2
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,389
    1,336
    Southern California,
    You obviously have a bad seal on the flapper. Place a few drops of food coloring in the tank and if this color appears in the bowl a few hours later, you know you don't have a good seal on the flapper. Many times it is just an accumulation of gunk under the flapper that can easily be cleared out using your finger. It also may be a bad adjustment on the chain and/or incorrect flapper.
  3. Feb 3, 2015 #3
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    Fluid masters Fill valves will syphon water from tank through the small refill tube if you have it stuck down inside the overflow. Does this toilet have a plastic overflow in the flush valve or is the overflow integrated in the china in the corner of the tank. The Fluidmaster comes with a clip to create and airgap above the water line so it does not syphon water out of the tank.
    is the flush valve plastic or brass?
    phishfood likes this.
  4. Feb 4, 2015 #4
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Feb 2, 2015
    10
    , New York State
    Thanks havasu and Mr_David for the quick advice!
    It has a china overflow in the LF corner and a plastic flush valve. The overflow tube is inserted at the very top of the overflow. The flapper seat was wiped clean when I popped on the new disc, and the chain seems to have just enough slack.
    I just added some of my wife's least favorite food coloring to the tank. Will check it in the morning and report back!
    Thanks, you are good guys!
  5. Feb 4, 2015 #5
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,389
    1,336
    Hey Guy, a picture would be worth a 1000 words. Could you post up a pic of your tank for us to look at? We might be missing something.
    I'm also wondering if the AS flapper is designed for this specific tank?
  6. Feb 5, 2015 #6
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Feb 2, 2015
    10
    , New York State
    See the photo of my American Standard one piece, now with red dye (food coloring) added. I'll check it tonight. Thanks for your help!
  7. Feb 6, 2015 #7
    phishfood
    phishfood
    phishfood
    Moderator Staff Member Professional Supporting Member
    Jan 18, 2010
    5,775
    992
    Orlando, FL
    I am suspicious that the overflow tube is pushed down into the overflow too far. As Mr. David mentioned, if the end of the tube is below the waterline in the tank, it will siphon water out of the tank.
  8. Feb 7, 2015 #8
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Feb 2, 2015
    10
    , New York State
    Thanks havasu, Mr_David and pfishfood,
    Your advice has been great! I have implemented all and improved the ghost flush cycle time to about 6 hours. Can I improve on that?
    The refill tube is far above the china drain water level. The chain is slack. I am suspect of the flapper valve disc. While it is new and the seat clean, also stated by the plumbing jobber to be correct, I believe it is the cause, or the entire assembly lower seal.
    Thanks again for your professional advice.
  9. Feb 7, 2015 #9
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,389
    1,336
    I have had manufacturer's flappers that leaked similar to yours. You might try a similar universal type flapper to see if this seals any better for you.
  10. Feb 7, 2015 #10
    speedbump
    speedbump
    speedbump
    Wells & pumps; not a... Professional
    Jan 6, 2010
    1,723
    212
    Riverview, Florida
    Anybody in the market for an Iron Filter?:rolleyes:
    havasu likes this.
  11. Dec 28, 2015 #11
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Feb 2, 2015
    10
    , New York State
    The ghost flushing, on my American Standard one piece toilet, just returned over Christmas! I've been going through the basics, tweaking the level and tube. No luck. The food coloring check shows leakage into the bowl. Over the next week, I'll replace the flapper disc and seal, once again. Will report back when I have a status change.
  12. Dec 28, 2015 #12
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,763
    2,408
    380th bomb wing ? 320 oms bomb wing Mather AFB B-52/KC135's
    MOS 43131-E aircraft maint. specialist- B-52 crew chief aircraft 58-217
    "Dropping the ace of spades"
    RetiredCarGuy likes this.
  13. Dec 28, 2015 #13
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,389
    1,336
    Run your finger on the seat of the flapper. Many times crud gets stuck under the flapper and it stops the seal from working correctly.
    Mr_David likes this.
  14. Dec 28, 2015 #14
    KULTULZ
    KULTULZ
    KULTULZ
    Jack of All Trades ~ Master of None Professional
    Sep 4, 2011
    1,534
    316
    Between Lost And Found, W (BY GOD) V
    Just the accumulated sediment in the bottom of the tank may be fouling the flapper valve.
  15. Dec 29, 2015 #15
    Mr_David
    Mr_David
    Mr_David
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    I hate AS toilets Old and New.
  16. Dec 31, 2015 #16
    phishfood
    phishfood
    phishfood
    Jan 18, 2010
    5,775
    992
    Orlando, FL
    Word up, dawg!:D
  17. Apr 3, 2017 #17
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Feb 2, 2015
    10
    , New York State
    It's back. More Ghost Flushing!!! And now an even higher frequency.
    I put in a an entire new flapper valve assembly, gasket and even a softer disc... Overflow tube is also set up higher above the water. The lever chain has more than enough extra slack and... It still leaks! How can anything so simple, be this stubborn. I just now added blue dye...
    What am I missing? Thanks to all of you in advance (again)!
  18. Dec 31, 2017 #18
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Feb 2, 2015
    10
    , New York State
    An old and necessary follow-up to this issue and my final solution. Not all new flapper valve discs are usable! Looking closely at the disc profile reveals that some are prone to leak even when new. Also pliable disc material necessary to seal each time. So choose wisely!
    Thanks very much to everyone! Happy New Year
  19. Jan 21, 2018 #19
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    986
    211
    Mansfield,, Ohio
    There are about three different angles on that assembly. Set your old assembly on a flat surface and then set the new one beside it and make sure the angles are the same. It has to be the correct one to work. If that is a porcilian seat check for any hair line cracks. Good Luck....
    havasu likes this.
  20. Jan 29, 2018 #20
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,463
    213
    Boston, Massachusetts
    if that's a one peice toilet it's a shallow tank there are numbers
    stamped I to the back of the tank they will get you exact
    replacement parts I think american standard had 2 different
    size discs for the flapper
Draft saved Draft deleted
Share This Page
