JohnnyStorm
Okay my plumbing experience is minimal but the wall was wet so I ripped it apart and this is what I see going on. Not sure what to make of this piping setup but it doesn't look correct to me. Anyway, I'll have to take more pics but the main issue here is there's a major leak coming from the upstairs bathroom sink drain. Which, in these photos, would be the middle pipe next to the electrical conduit, in between the toilet drain and bathtub drain. You can't actually see the leak with these pics because the actual connection where the leak is sprouting from is behind the beam. If am going to fix this I figure I may as well replace this whole setup with PVC since I'm here. BUT is that what I should DO??? What's you're opinion? These are phots of the 1st floor bathroom. Above this ceiling is the second floor bathroom built, dimensional wise, identical. Thanks for any help in advance!
