Flushing problems: Is it the plumbing or the toilets?
Discussion in 'Toilets and Sinks' started by Bleb Nevus, Nov 7, 2018.
  1. Nov 7, 2018 #1
    Bleb Nevus
    Bleb Nevus
    Bleb Nevus
    Nov 7, 2018
    Boston
    I have no plumbing experience, so this is a very basic question. I moved into a newly constructed condo six years ago. Over time, all three of my toilets -- American Standard 4010 -- have given me problems (intermittently, not constantly). Either they back up and have to be plunged or they seem to flush reluctantly. I'm open to researching and buying replacement toilets (or bowl only? tank only?), but I'd hate to do that if the problem turns out to be clogged or defective pipes. How do I know?
  2. Nov 8, 2018 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,083
    153
    Boston, Massachusetts
    i have 2 American standard toilets exactly identical one works fine the other flushes fine most of the time but doesn't finish the flush other times I never like these toilets but
    the one that flushes fine is on the main floor so we don use the other that much I have change everything in the tank used exact replacement parts cleaned the jets and any other holes in the bowl they are older 90s toilets …….. my guess is it your toilets....in the back of the tank there are numbers either stamped in the tank or printed on itthere are 4 numbers probably the onesyou mentioned....those wil give you exact replacement parts...try that on one toilet first and see what happens....the flapper may have a yellow float...read the back of the package....you need to put the flapper a certain number of beads away from the flapper
  3. Nov 8, 2018 #3
    voletl
    voletl
    voletl
    Dec 18, 2014
    620
    196
    New York
    Fill a rather large bucket with water and dump it into each of the toilets if the water goes down perfectly fine then it's the innards of your toilets that are messed up if the water backs up then you have some type of blockage
  4. Nov 9, 2018 #4
    Bleb Nevus
    Bleb Nevus
    Bleb Nevus
    Nov 7, 2018
    Boston
    Thanks for these replies. Wondering if anyone else who has experience with these things might weigh in...
  5. Nov 9, 2018 #5
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    319
    67
    The two guys above are plumbers, so I would guess they have seen this before. They have given you the answer on how to diagnose your problem. What else are you looking for?
    mike fiore and GReynolds929 like this.
  6. Nov 10, 2018 #6
    mike fiore
    mike fiore
    mike fiore
    Aug 18, 2018
    120
    28
    exeter rhode Island
    Its unlikely but i have seen clogged vent pipe cause issues. I changed old toilet out for a customer for those same reasons thinking its an old toilet and jets are clogged. Installed new toilet and had same issues. finally checked vent from roof and found clogged with leaves or some type of nest. once i cleaned vent pipe toilet worked great. not saying thats the issue but it might be worth a look.
  7. Nov 15, 2018 #7
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,065
    202
    North reading, Mass.
    You say,"Either they back up and have to be plunged or they seem to flush reluctantly."
    Does this happen even when you are not flushing any solids?
  8. Nov 16, 2018 #8
    Jamesplumbing06
    Jamesplumbing06
    Jamesplumbing06
    Feb 24, 2016
    556
    111
    That model number was the contractor special 10 years ago. You ever met a contractor that buys the quality stuff? Me either. I change them all the time. They have 1-3/8” throat for trap. But the new American standard champion 4. Yeah baby that dude flushes. Toto is great. Kohler has the dual siphon. But the champion 4. I could be a salesman for them. So it’s not a brand specific just a model specific.
Share This Page
