I did work at a house where the husband had drained the pool in the summer in the rainy season. This was years ago and I'll bet she's still not speaking to him.It's like seeing a pool come out of the ground when drained. Makes you wonder how battleships don't sink.
Maybe 8 or so years ago, a helper and I were doing a rough up in Palm Coast, big custom house. We had the PVC drainage in, had the sewer in, had the waterpipe on the inside done, and almost had the water main dug. We were going to hook up the water main and then open the meter to use the water to fill the drainage pipe.Speedbump, I have also seen that happen up north with oil tanks. Down here I'm sure you have also seen a slab rough in PVC float out of the ground when left uncovered or not filled with water for a test.
John
That is a strange set up. Is that the pump chamber? The normal set up is with the septic tank closer to the home then the pump chamber after the tank.
John
It took the two of us 6 hours to dig it back up and reset the pipe the next day.
