Hello all. Happy the forum is available
I am looking to run a three hundred twenty foot well to only fill up a water storage vessel that is about fifteen thousand gallons. I am hoping to run the pump with an above ground storable wire coming from my panel or plug it into a generator. The static level of the water is about ten feet below the surface and the production is about eight gallons per minute. From my understanding the three wire pumps last a bit longer which is seen in many things from lack of heat buildup running lower amps. I understand all wells have smart shut offs now and intelligent restart attempt timing. Im looking to connect to a camlock at the threaded caps which I hope I can get in a two inch port and hose, min. Any tips or tricks for a green horn are welcome.
My issue is I have been searching and I do not know where to look or when found, what works best. Any advice would be more then appreciated.
Also, for the winter, would I need to do anything or would, with the cam lock, the water should fall well below the frost line?
