Faucet Supply Line Question
watercamper
Feb 25, 2015
13
TomFOhio
Professional
Professional
Jan 20, 2018
1,072
224
Mansfield,, Ohio
You need to show a picture of what you want to do. I don't know what your talking about a ground
connection for a faucet.
watercamper
Feb 25, 2015
13
Thanks Tom. I called the mfr and asked them. They couldn't tell me what the verbage meant either. So, I threaded on a !/2" IPS sharkbite with teflon tape and pipe dope. No leaks. Good to go.
Diehard
Aug 19, 2017
2,572
447
North Reading, Mass.
I would call the mfr again and if they know ask them to check with technical or engineering group.
Now that we have a picture, maybe a plumber will know.
watercamper
Feb 25, 2015
13
That's what I did. The person that answered was emailing with technical. I had to direct the person on the questions to ask. I finally got that !/2" FIPS would work but the answer wasn't totally reassuring if you know what I mean. Still, the sharkbite fitting worked fine. Just weird that the mfr would print something like that.
frodo
Just call me Macgyver
Professional
Supporting Member
Sep 28, 2014
7,980
2,510
A ground joint is a beveled connection, that a lav supply cone nut faces up to
you can use a braided flex connector to hook up the water
or theses lav nuts and a supply tube
or a female adapter
havasu
Administrator
Staff member
Admin
Jan 5, 2010
9,474
1,360
Southern California,
So, just so I understand correctly, this faucet is designed for just one supply line, and either for hot or cold water only?
havasu
Administrator
Staff member
Admin
Jan 5, 2010
9,474
1,360
If you like Shark Bite fittings. I personally use them only for temporary fixes, and don't consider them a permanent fix. Yes, I know some do, I don't.
TomFOhio
Professional
Professional
Jan 20, 2018
1,072
224
Mansfield,, Ohio
Wow, thanks frodo. All the years that I have been doing this I never heard that. Used them quest supply
lines for years. Thanks for that info....
Group Builder
