Faucet Handle Removal
Discussion in 'General Plumbing Help' started by charrbrad, Jan 5, 2019.
  1. Jan 5, 2019 #1
    charrbrad
    charrbrad
    charrbrad
    May 27, 2016
    17
    Hi....hoping someone can help. I have a strong leak in this faucet and I need to remove the faucet handle. Can someone assist?
  2. Jan 5, 2019 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    795
    122
    Boston, Massachusetts
    are you able to remove the screw from the handle????? have you tried giving the handle a few good taps from the back side or spaying it with clr or vineagar????
  3. Jan 5, 2019 #3
    charrbrad
    charrbrad
    charrbrad
    May 27, 2016
    17
    That did it....thank you. One question, I now see the stem....is there a special tool needed to remove and replace the washer? I’m totally lost
  4. Jan 5, 2019 #4
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    258
    55
    Once you have the handle off, remove the Bennett (bell shaped chrome cover). Then you will need a deep socket to remove the stem. You can buy a set of those deep sockets at home depot for around $10. Remove the stem ( be sure you have turned the water off first) and remove the small screw and old washer on the bottom, and install a new one.
  5. Jan 5, 2019 #5
    charrbrad
    charrbrad
    charrbrad
    May 27, 2016
    17
    Thank you both, I appreciate the help.
  6. Jan 10, 2019 #6
    charrbrad
    charrbrad
    charrbrad
    May 27, 2016
    17
    This is the stem that was removed. Any idea where I can get a replacement? The sink is very old.
  7. Jan 10, 2019 #7
    jeffmattero76
    jeffmattero76
    jeffmattero76
    Nov 3, 2017
    258
    55
    I would suggest bringing it to a plumbing supply house.
Share This Page
