Quantcast
Fan Light Night Light
timkins4292
Active Member
Jul 21, 2020
27
Victor, NY
Have a Fan Light Night Light just above my shower stall. Went outside this morning and I have a huge icicle in my gutter just below the roof cap exit for fan. Took the fan down from the ceiling and tried to insulate the housing. There is a 4watt incandescent bulb for a night light and a 26 watt fluorescent light. They are both housed in a metal cabinet. How would I insulate the housing to prevent heat loss thru the duct. I am reluctant to use duct tape or anything flammable to stop the flow to the outside. We have stopped using the fan and only use the night light sparingly.
Twowaxhack
Feb 9, 2021
738
238
United states
How would insulating the fan housing stop ice from forming outside ?
You need a HVAC person for advice. Sorry I couldn’t help.
Twowaxhack
Feb 9, 2021
738
238
United states
So if you insulated the fan it then that would cause more ice it seems.
It should have a damper in the fan to prevent the free flow of air to the outside.
timkins4292
Active Member
Jul 21, 2020
27
Victor, NY
How do you figure that? If the source of the heat thru the housing and then the duct is blocked then no heat transfer takes place so then no defrosting takes place and no icicles appear.
Twowaxhack
Feb 9, 2021
738
238
United states
Ok great. The fan should have a damper built onto the outlet.
If it’s not there then install one.
This stops a warm draft from exiting through the fan.
That’s all I can help with. Have a great day.
Jeff Handy
Jul 5, 2019
3,617
947
Chicago suburbs
It would seem the melting of snow is causing your giant icicle.
The snow is likely melting from the fan’s warm exhaust blowing onto the snow on the roof.
Stop using the fan, just leave the bathroom door open during showers if you can.
Insulating the fan box or the duct will not stop that melting problem.
The reason people insulate the fan box and the duct is to stop condensation from forming inside the cold duct, which then can run down into the fan and cause a drip, drywall damage, or rust out the box or fan motor.
All this heavy snow is giving millions of people a big problem with giant icicles and ice dams, just look at your neighbors’ houses, that’s just how it goes.
