Installing submersible well pump in wet well on pond. Need 20 gpm. Pump supply house Sized pump at 230 volt, single phase, 1hp, 3 wire with pump control box. There is 480 3 phase at location for large pump that feeds pivot system. The electrician said we need 480 volt 3 phase pump. Pump supplier said that 1hp pumps are not available in 3 phase 480 and there needs to be kick down transformer installed to 230 volt single phase. Who is correct and which way should I go?
